DC w/broken cranshaft
Ande
08-22-2007 05:19:40
I bought a "DC" 1949 last weekend,it has a broken crankshaft.I really havent heard of the "DC"s doing that,this guy told me it had been overhauled too,which leads me to beleive maybe something happened then.
Ande
farm-al
08-22-2007 19:02:08
 Re: DC w/broken cranshaft in reply to Ande, 08-22-2007 05:19:40
the old DC's used an unfinshed main bearing that had to be line bored when replaced I have seen the crank break when someone tried to adjust the clearence by adding or removing shims on new bearings. farm-al
Pulled a DC
08-22-2007 11:11:59
Check the rear main cap area on the block for cracks. They have been known to give up also.
dboll
08-22-2007 08:33:13
they broke several, I know of some personally, especially if equipped with big pistons and lugged on low grade fuel, loose mains also contributed to the problem
Ande
08-22-2007 09:55:45
 Re: DC w/broken cranshaft in reply to dboll, 08-22-2007 08:33:13
Thanks for the info,I wonder myself if something wasnt quite right after the overhaul.
By the way,do you still have your "A6"? I did get one as I never heard back from you.If you still have it let me know,I had a friend going that way,wouldnt hurt you have another!
Ande
Ande
08-23-2007 05:56:19
 Re: DC w/broken cranshaft in reply to Ande, 08-22-2007 09:55:45
Wanted to thank all of you for your information.I hadnt realized that the "DC" had those type of issues.Kinda like the first "1175""s.I think I have located another "DC" with a good motor.Will keep you updated.
Ande
