hydrualic pump
l gehring
08-21-2007 19:51:19
i have an sc case with a hydrualic pump between the govenor and the mag. there are 2 numbers on the housing. vt607 and vt609 along with the case eagle cast in. it leaks. i took it apart, the mag end has a number cr vt 4897 on the seal, the one on the govenor end has no number. i tried case ih web-site and did not find any thing. have any of you had any experience with this pump?
Paul f
08-23-2007 06:22:36
 Re: hydrualic pump in reply to l gehring, 08-21-2007 19:51:19
Pump sounds like the ones used on later model VACs.
FYI the VT4897 seal is CR 8648
I couldn't find a newer "A" series part number for the other seal (my VAC manual calls for a O4244AB)
The CR interchange manual will cross the "A" series Case numbers (and most of the VT series) but not the older "O" series...sorry
