case 311 1956?? loader hydraulics??
danny waters
08-21-2007 17:31:46
I bought a 311, round nose, triple range with 1 aux. output, I also got a kelly loader with it. the mounts wer on the tractor. the loader was in the barn, It had all the lines missing. How do I hook this to the tractor hydraulics. I already bought a new 2 spool valve. Any other info I should no aboutthis tractor?? All tires have plenty of tread, dash is junk, also got a nice 5 foot bruch cutter with it!! $800.00 and I got his craftsmen riding mower too!! Thanks
danny waters
08-22-2007 15:41:48
 Re: case 311 1956?? loader hydraulics?? in reply to danny waters, 08-21-2007 17:31:46
yes it has a eagle hitch, it has 1 aux. hyd. out put also. all 3 cylinders are double acting. One thing I didnt mention was it has some sort of a valve for the eagle hitch line. The supply line comes from under the fuel tank, into this valve(???) then a line goes into the top of the tranny housing and other to the rear for the eagle hitch. The loader was on this tractor before, but all lines are missing now. I would like to hook it up where I still have my aux. output on the back????? Thanks
Joe (Wa)
08-22-2007 22:58:11
 Re: case 311 1956?? loader hydraulics?? in reply to danny waters, 08-22-2007 15:41:48
Without eyeballing what you now have, I can't do this long distance.
Joe
Joe (Wa)
08-21-2007 21:37:43
Do you have an Eagle hitch?
Do you have 2 hydraulic control valves mounted under the gas tank?
Are your loader lift cylinders double acting or single acting? Ditto bucket cylinder?
Roger Hornbaker restores 300 instrument boards. [email protected]
Joe
Lincoln
08-21-2007 19:25:55
You should be able to plumb into the metal hydraulic line that runs to the 3pt. (enters the rear end near the seat) Put a valve in it so one way runs to the 3pt., the other way runs to your two spool valve.
