what kind of oil?
Rick Lawson
08-20-2007 08:04:09
I have a 1969 case 430 gas engine tractor. The owners manual says use sae20 for engine oil. use sae90 for tranny and use case tch for differ. That was in 1969 what can you use in 2007. Thank you for your help.
Jim B
08-20-2007 20:55:43
 Re: what kind of oil? in reply to Rick Lawson, 08-20-2007 08:04:09
You can still buy the PROPER oil as specified in the operators manual, by the engineers that designed them.
C. Amick
08-20-2007 19:35:56
I've always used SAE 30HD in the summer and perhaps the SAE 20 in the winter. I guess I use it because that's what my dad used. A multi-viscosity oil should also work fine.
Doc Larry
08-20-2007 17:27:11
On these tractor boards, this is a classic "start an argument" question that comes up all the time although that"s obviously not your intent. I"ve run 10w-40 Valvoline for about 35 years in a number of gas engines that I eventually tore down and rebuilt, and I can"t imagine a better oil although it is not suited for some of the modern gas car/truck engines which crave 5w-30. But some folks don"t like multi-viscosity. I really think if you use a good quality detergent oil, either multi-viscosity or not, you"ll get good results if you treat your engine right and change oil and filter on schedule.
Larry
Skyhawk Greg
08-20-2007 13:07:29
I probably will get lambasted for this, but I have a gas engined 1966 580CK that I use 10-40 in the engine. In the shuttle shift transmission and the loader/hoe, I use universal tractor hydraulic fluid from TSC. This has worked for the last 15+ years.
