Identification of a Case disel tractor
Helen Brymer
08-19-2007 14:04:30
We have a Case Disel Tractor, with identification numbers: 25404 or GD 157. These numbers do not correspond with the serieal numbers under the Case Tractors. Does anyone know when this tractor was manufactured, or if the numbers we have are not the correct model or serial numbers? Thank you for any information.
george md
08-19-2007 17:49:06
 Re: Identification of a Case disel tractor in reply to Helen Brymer, 08-19-2007 14:04:30
Helen, The number GD 157 is the model of the engine that was used in the 300 series tractors made from 55 thru 57. Those tractors had a curved grille with large medalion (plastic ) at the top. The GD 157 is a G series diesel continental engine. The " B" series also used the GD 157 in the 300 an that series had flat front grille with the head lites above the grille. The serial plate is on or under the dash and is held on with two screws or rivots .
george
