Case Model 831 diesel how to put it in high range?
msdcreasy
08-18-2007 12:59:33
Hi, I hope you all can help me, my boyfriend is working on his Case Tractor and can"t figure out how to put this thing in high range. It is a case model 831 dual range diesel, manual trans. Old tractor. Can anyone please help?
djm75
08-19-2007 04:03:22
 Re: Case Model 831 diesel how to put it in high range? in reply to msdcreasy, 08-18-2007 12:59:33
don't know what year you got but mine also has the double shifter and the range selector is on the left. If you could get us more info we could help you out better. good luck
DKase
08-18-2007 17:34:11
If it has only 1 shifter, there is a vertical neutral slot between 3rd, and 4th that will take you up to high range which includes 5th through 8th. Hope that is explained OK.
jaker2
08-18-2007 17:38:14
 Re: Case Model 831 diesel how to put it in high range? in reply to DKase, 08-18-2007 17:34:11
Afraid to disagree, but on a single stick the neutral is between 2nd and 4th.
CJ_1080
08-18-2007 13:57:28
Hey this chick is prety hot and handy! Comming on here to help out her boyfriend! You got a twin sister? If not how about a new boyfriend that can kick it into high gear??
bradley martin
08-18-2007 13:33:31
It depends whether it is a early version or a later version...also whether it is the mechanical transmission or the Case-o-matic. Early models w/standard transmission only had 1 gearshift that not only changed gears but also shifted ranges....it can be confusing until you get used to it. After sn 8173401, they went to to 2 gear shifts ( initially both on top of the trans. lid and later the range shift was linked to a lever on the dash just to the left of the steering shaft. ) If you could find out if it is mechanical or Case-o-matic and the serial # it will help to give you specific instructions.
J kemp
08-18-2007 13:30:09
Put tjhe durn thing in gear and take -off ,,,cheesh ,,there could be a broken fork or something mechanical ALLFOULED , loused -up ,,, DOES THIS ONE HAVE A SMALL SHIFTER ON THE RIFGHT SIDE OF DASH,OR IS IT A DOUBLE HAND SHAKER ,,How much time have you been around this tractor and other tractors ,, IN SHORT IS YOUR EXPERIENCE WITH TRCTORS OR TAXI CABS ,INTERNET SERVICE AND METER READING ,OR stalkinshelves at the Walmart
TexasWren
08-18-2007 19:21:45
 Re: Case Model 831 diesel how to put it in high range? in reply to J kemp, 08-18-2007 13:30:09
On the 830, the range shifter is on the LEFT of the steering. At least it is on mine.
J Kemp
08-18-2007 14:51:57
mY aPOLOGIES TO ALL ON THIS exassperrating HOT DAY ,similar situation , Case inpoint nephew just called me away , to tell me 430 will not move , After going to the feild and finding him , I simply stuck the range selector in gear , He had it in Neutral
Engineer20
08-18-2007 13:37:11
Well we know that she has better use of the English language than you do.
