No. 10 Case mounted mower
Jerry W
08-17-2007 19:31:08
I am in need of a Pittman arm for this mower and my local dealer was not help. Any know where one can be found.
Jerry
bradley martin
08-18-2007 13:40:32
 Re: No. 10 Case mounted mower in reply to Jerry W, 08-17-2007 19:31:08
You can easily saw 1 out of a piece of hard maple, white oak , hickory or simialar wood, drill your holes and you are in business. It should also not be too hard to calculate the length.
flying belgian
08-18-2007 07:19:44
I have a #10. Its the same arm as a New Idea. I got mine from TSC.
watsonsgotit
08-18-2007 04:58:37
I went to the local farm store and purchased a universal one. Took it home cut it off and redrilled it. Matched perfect.
BarryfromIA
08-17-2007 20:13:02
If your have the old one, some of the farm stores have a universal pitman stick. You might be able to redrill one that would work.
Jerry W
08-18-2007 12:31:20
 Re: No. 10 Case mounted mower in reply to BarryfromIA, 08-17-2007 20:13:02
Part of my problem is that I only have the ends. It was broke when I bought it. If someone had the dimensions that would be nice. What model New Idea?
Jerry
Paul f
08-18-2007 14:18:43
 Re: No. 10 Case mounted mower in reply to Jerry W, 08-18-2007 12:31:20
I have an EDSC-7 but I have accumulated a couple of other mower manuals. I have one for a T10 trail type says pitman is 41.5".
It also seems you should be able to determine the length. I will have to go to the barn tomorrow and check mine but it seems to me that with the crank at the 9 or 3 o'clock position your cutter sections should align with the stone guards (that is how you check register, at the end of a stroke)...measure the length you need at that point.
BarryfromIA
08-18-2007 15:09:06
 Re: No. 10 Case mounted mower in reply to Paul f, 08-18-2007 14:18:43
I have a t10 I would put in the classifieds if there is any interest. in it.
Paul f
08-18-2007 16:37:32
 Re: No. 10 Case mounted mower in reply to BarryfromIA, 08-18-2007 15:09:06
Where would it be located...UPS would have a problem with it :-)
