case 800
leecramsey
08-16-2007 21:41:27
Anyone,
I am asking for my brother-in-law so I may not have all the pertinent information so please bear with me. He has an automatic transmission on his case and he says when he goes down a hill it "pops out of gear". He can slow down and it reengages. Is this a normal function (I think not)or what are some posssible causes. i may need to check back with him for proper info. TIA
Lee Cramsey
lee cramsey
08-17-2007 22:21:38
 Re: case 800 in reply to leecramsey, 08-16-2007 21:41:27
He does need more info on case-o-matic. He only uses this tractor sparingly. He has 11 other old tractors. Thanks for the input I will relay and see if it helps. Lee
JGarner
08-17-2007 16:59:24
Jerry is talking about the right hand handle. The left hand one is the throttle.
Jim B
08-17-2007 22:16:40
 Re: case 800 in reply to JGarner, 08-17-2007 16:59:24
Wrong, on an 800 both the COM lever and the hand-throttle are on the left side of the steering wheel. The COM lever moves up-down, up is direct drive, down is torque-converter drive.
The hand throttle swings on axis with the steering wheel. Idle is full clockwise, Higher RPM's is counter-clockwise.
Jerry h
08-17-2007 04:39:29
I think he needs to learn about case-o-matics. Tell him to pull the knob handle up pn the lever under the steering wheel, this puts tractor in direct drive.
J Heitkemper
08-18-2007 19:28:00
 Re: case 800 in reply to Jerry h, 08-17-2007 04:39:29
If the fellow is new to the tractor and has no experience with Case -O matic .. LEARNING EXPERIENCE NEEDED . Thats what it sounds like to me also ..,Pull up the engaging Lever on the steering column .. If He is Well versed than We should continue to sort thru the problem , Return Answer . JIM
lee cramsey
08-20-2007 20:16:54
 Re: case 800 in reply to J Heitkemper, 08-18-2007 19:28:00
He is not well versed, but is familiar with the tractor. Today he told me it pops out in direct drive and torque drive while going down a hill.
Lee
