add-on hydraulic pump
l gehring
08-16-2007 20:06:41
i have an add-on hydraulic pump on my sc between thr govenor and the mag. it has a small but steady leak where it meets the mag. if the seals on both ends are leaking, is it possible that i am pumping oil into the engine through the govenor housing? i was going to fix the pump when i had time. thanks for any info.
C. Amick
08-17-2007 12:05:55
 Re: add-on hydraulic pump in reply to l gehring, 08-16-2007 20:06:41
Yes, I would think it could leak into your engine oil. The Farmalls that had the hydraulic pump up front at the timing gear also would leak hydraulic fluid into the engine.
