Which thermostat and plugs for an 800
INCase
08-16-2007 14:52:15
I"m getting closer to getting the 800 back together and was going to put a new thermostat in. I see the 730 thermostat has a lower temp range than the one listed for the 800"s. Which would be better? Are they available? Also, what brand/type spark plug has worked well on these? It"s gas with LP heads. Thanks again.
casetractor700
08-20-2007 14:38:48
 Re: Which thermostat and plugs for an 800 in reply to INCase, 08-16-2007 14:52:15
you would be ahead to run the 800 thermostat higher temps helps rings seal better and burn cleaner. i have a 700 gas that i pull, it has lp heads and i use c87 ac plugs stay away from champion any other is okay but i have had good luck with ac ive only fouled one in 8 years
