Case- hydralic pump
vabill
08-16-2007 03:48:04
i have a case 385. i have to rev it up to get the loader to rise, could this be the pump or what? also where is the pump located? thjank you bill
John Studdard
12-27-2007 14:14:43
 Re: Case- hydralic pump in reply to vabill, 08-16-2007 03:48:04
the pump is behind the filter,it may need a new filter are someone may have the bypass valve and screen in the case backwards ,the screen goes to the out side or bottom of canister not against the houseing, go to www.messicks.com/nhparts.aspx?=case look at the filter ,also the mutiple cntrol valve may be malfuctioning, hope this helps
