930 8-speed clutch pedal does not fully return
clutch-in-texas
08-15-2007 19:04:01
I just got a case 930 late model CK 8speed. I have not driven it much but it looks like the clutch is not fully returning after it is depressed.
Linkage adjustment? Pressure plate problem? Return spring? Is splitting nessary?
Thanks
Gary in Pulaski
08-16-2007 19:37:48
 Re: 930 8-speed clutch pedal does not fully return in reply to clutch-in-texas, 08-15-2007 19:04:01
I'm not so sure about that pivot point diagnosis. I have an 830 with the same problem. All the joints seem more than loose enough. I have more than enough free play, but sometimes the clutch just won't return all the way! Then as I go down the field and go up a hill or turn a short corner, the clutch begins to slip. (Better fix it before I burn it up!) I think that maybe the throw out bearing is hanging up on the shaft. I'll need to open up the side inspection hole to see what I can. Any other ideas or advice?
bradley martin
08-16-2007 03:14:47
Start with the simple things first. Is the return spring good, is the pivot pin lubed, is the linkage adjusted properly? Don"t go splitting the tractor until you check out all the external components.
JW
08-15-2007 19:09:27
This will sound stupid but you probably just need to spray the pivot point with lube. Its common for that to get dry and not let the pedal go back.
