Need help identifying Case model
Fillroy
08-15-2007 18:41:42
Tag on dash has model #840CK Serial #8310070 Tractor is LP, has 377 cubic inch 6 cly engine, 23.1 x 30 rear tires, 7.50 x 18 front tire, and hand clutch
Thanks in advance for your help
Fillroy
Kase
08-16-2007 18:22:52
 Re: Need help identifying Case model in reply to Fillroy, 08-15-2007 18:41:42
Sounds like a 900 or a 930 Wheatland with a 830 serial tag.
Nedd
08-16-2007 05:48:03
I would say someone changed your dash or changed the motor. But either way it should be a good tractor. If it has a wide front 830/840 had one clamp on adjustable axle, 930 has 2 clamps.
Lincoln
08-15-2007 21:13:25
The model is generally known as the 830 Comfort King. Yours is the model 840 variant of the 830. The specific model number is different depending on the style and engine type, however the whole series was called the 830.
Klyde
08-16-2007 04:22:05
 Re: Need help identifying Case model in reply to Lincoln, 08-15-2007 21:13:25
Never saw a 6 cylinder 830!!!
