BEARING CARRIERS LEAKING
TIM GREENE
08-14-2007 17:41:05
I HAVE A CASE 400 WITH LEAKY BEARING CARRIERS. THESE CARRIERS HAVE NOT BEEN REMOVED SINCE 1957. WHAT IS THE BEST WAY TO REMOVE THEM WITHOUT BREAKING ANYTHING ELSE? AND WHERE IS THE BEST PLACE TO FIND THE REPLACMENT SEALS. THANKS
Roger R
08-15-2007 20:22:43
 Re: BEARING CARRIERS LEAKING in reply to TIM GREENE, 08-14-2007 17:41:05
I just went through this with an 800. There are several places to wedge a small chisel under a lip. Just go slow a little on each side and it will work out. The case dealer will tell you one of the two seals is no longer made. The seal for a 930 is the replacement for both. You can get one from John Saeli. Roger
Charles Santhuff
08-15-2007 05:45:38
Case dealer.
