580B CK Gas motor
DSLRandy
08-13-2007 10:12:06
I bought this old backhoe it was sitting outside for 3 years, however I did manage to get it running, everything works, however there is a loud whine noise(hydro noise)when I press in clutch the noise goes away. I looked for a oil dipstick on the trans but only found one on the rearend just down from the shifter. should it have one or is it all in one?
Skyhawk Greg
08-17-2007 19:55:46
 Re: 580B CK Gas motor in reply to DSLRandy, 08-13-2007 10:12:06
Hi Randy,
The dipstick you found should be the right one. I use Case TCH oil. It probably doesn't really matter that much if you use a universal tractor hydraulic oil. I was told by an old Case guy to not worry about the whining if it is used at home. Not worth the money to get rid of it.
Greg
