420G backhoe idle RPM and gov adjust
Greg Lasher
08-10-2007 18:34:11
Can someone tell me the idle and high speed RPM for a Case 420G (gas) backhoe? Also the does not like to let the engine idle and with just a light pull on the spring it is off to the "races". The linkage is not binding and so far as I can tell is adjusted correctly. Could one of the weights be stuck inside? When the engine is running if you push the throttle shaft to wide open on the carb the govonor pushes back so I assume it is trying to work. The gov. sping matches the paint on the tractor so I assume it is correct.
Ideas please....??
Thanks
Greg
