Hydraulic Cylinder Repair
BobV
08-09-2007 13:14:08
Hi everybody, got one of the old Case hydraulic cylinders and need to replace the rod and new seal, any idea where I can find parts for this unit or anybody repairing them.? Thanks in advance.
C. Amick
08-13-2007 15:49:54
 Re: Hydraulic Cylinder Repair in reply to BobV, 08-09-2007 13:14:08
You may want to price a generic hydraulic cylinder. Some of the hydraulics shops are pretty expensive. Where are you located?
flying belgian
08-11-2007 15:06:02
you can fill the pits in the rod with jb weld. sand it down and it will work fine.
bradley martin
08-09-2007 16:42:40
Seals are available from Case or any bearing supply store.As far as a new shaft, you are likely looking at a custom machine shop job.
wayne2
08-09-2007 17:21:51
 Re: Hydraulic Cylinder Repair in reply to bradley martin, 08-09-2007 16:42:40
If you sand (fine)shaft could-might-maybe get couple years out of it!!! Wayne
Paul f
08-10-2007 14:35:19
 Re: Hydraulic Cylinder Repair in reply to wayne2, 08-09-2007 17:21:51
If it is a one-way cylinder as in an eagle hitch I would suggest checking the cylinder bore...corrosion here will cause it to settle. Actually other than being messy a pitted shaft really won"t affect the lifting. If you find a solution to corrosion in the cylinder bore please, please, please let me know. For now I replace the big O ring frequently, as the corrosion tears them up....
BobV
08-11-2007 06:30:44
 Re: Hydraulic Cylinder Repair in reply to Paul f, 08-10-2007 14:35:19
Paul F. sorry this is a twoway cylinder used for implements the rod was so badly damaged that it started on the outside seal I'm looking into making a new rod and sleaving the old seal, good luck on your problem BobV
