DC case block identify.
shade tree cat
08-09-2007 05:32:19
have 2 dc blocks how can i tell if it is 4in or37/8.bore without pulling heads off? where is sn. for block heads etc.
BasketCASE
08-10-2007 07:07:19
 Re: DC case block identify. in reply to shade tree cat, 08-09-2007 05:32:19
Blocks should be the same. The only difference is in sleeve wall thickness. If someone rebuilt the engine somewhere along the way, they may have used 4" pistons.
shade tree cat
08-10-2007 05:37:45
Nedd do you mean that all dc were 37/8 from factory and the only way for it to be 4in is if some time in its life it was converted to 4in.?
Nedd
08-10-2007 09:19:16
 Re: DC case block identify. in reply to shade tree cat, 08-10-2007 05:37:45
Not all DC's were 3 7/8" from the factory. But most were, Rich Tworek (spelling?) at Case/New Holland can get you build information on your DC for a fee. Some came out stating "high altitude aluminum pistons." I would say about 80-90% have been converted. Out of 11 D series tractors I've worked on, only 1 had the 3 7/8", 3 had 4 1/16", and the other 7 had 4". Hope this helps.
Nedd
08-09-2007 05:55:33
No serial number difference. Just depends on if someone changed pistons in the last fifty years. Take a side cover off the oil pan and try to measure the bottom of the sleeve. Those side covers are meant to pull a piston without pulling the head. (According to the manual.)
