Case 800 to730
Texas Denny
08-08-2007 06:56:41
Does anyone know if I could use the transmission, clutch and flywheel from a 730 to convert my 800 to a 700 (non Case-O-Matic)?
Jim from Calif
08-08-2007 17:51:22
 Re: Case 800 to730 in reply to Texas Denny, 08-08-2007 06:56:41
In addition to the below, You will need the "Steering Support Fixture" from the 730. The 800's is too short for the clutch unit.
INCase
08-08-2007 07:40:39
I hope so. I"m planning to do that as well once I get the 800 running right. I"m quite positive it can be done. change the flywheel and the oil pan will need to be changed as well. I believe the battery tray mount is a bit different.
scman
08-08-2007 08:06:45
 Re: Case 800 to730 in reply to INCase, 08-08-2007 07:40:39
You will also have to change the top shaft in the transmission. I don"t know that the battery tray is any different, unless you are going from a gas to diesel.
INCase
08-08-2007 09:40:00
 Re: Case 800 to730 in reply to scman, 08-08-2007 08:06:45
Are you talking about only changing the clutch or torque tube (bell-housing to transmission) or the whole rear end (bell-houseing to hitch)??
