Need tachometer drive cable housing
idahospudluvr
08-07-2007 21:47:45
I am needing a tachometer drive cable & housing for a 1959 Case 801-B. Any ideas on where you can find one? If only the housing is found I can get a universal speedo cable correct?
Roger in Iowa
08-08-2007 05:40:28
 Re: Need tachometer drive cable housing in reply to idahospudluvr, 08-07-2007 21:47:45
If you have remnants of the old housing, to include the ends, take it to O'reilly's or NAPA and they can usually look in their books and find something that will work.
Recently did it for a JD combine. Saved over $100.
Regards,
Roger in Iowa
idahospudluvr
08-08-2007 12:44:04
 Re: Need tachometer drive cable housing in reply to Roger in Iowa, 08-08-2007 05:40:28
Thanks Roger, Never even thought of doing that. Will give that a try. I have the end that goes in the motor, as far as the other end it looks like a stock speedometer end.
