800 Case-o-matic Hard to get in gear!
Delbertcm
08-07-2007 07:15:32
Acts Like the clutch is not releasing, I have checked and clean valve body, And checked & cleaned the regulator. Converter pressure good 150 psi at Idle or wide open! Anything you could help me with I thank you!
delbertcm
08-10-2007 16:27:55
 Re: 800 Case-o-matic Hard to get in gear! in reply to Delbertcm, 08-07-2007 07:15:32
Thanks for all the repiles! I have changed all the fuilds. Have gone thur all tests with I.T. Manual, set all adjustments. I have owned this tractor since Dec. And it worked fine. I have run and repaired these tractors for 30 years. I talked with a farmer who has had them apart. sounds Like I have a bearing out or a lip seal bypassing. Will spilt it this weekend. I know something isn"t right as when in gear with clutch in it will still move! This is a fleid tractor and used as such! I"ll let you know what I find!
Lincoln
08-08-2007 08:34:00
Motor has to be at an idle when putting them in gear. Even then they can grind some.
J Hi kemper
08-07-2007 23:17:55
Change torque converter fluid to Detron 3 .. Get an IT book ,, Make sure spools are centered well on clutch mechanism .. Do you have a long history with this tractor , or did You just get it ?,, Good Luck , Jim
wayne2
08-07-2007 21:03:18
They'll do that get er in a field -not a yard tractor. Wayne
