Where are you putting the hydraulic oil?
Roger (Mi)
08-06-2007 19:06:39
Hydraulic oil (TCH) should ONLY be added to the torque tube reservoir (plug near the hand clutch lever) forward of the foot clutch. The rear end has a measuring rod on the fill plug (near the left side of the driver's seat) and its FULL mark is very near the bottom of that measuring rod. When the rear end (90W gear lube) is filled properly, there is no possible way for oil to come out of the rear end vent. If it's over filling with hydraulic oil, there has to be a crack in the rock shaft housing, scoured rock shaft cylinder, defective O-ring on the rock shaft cylinder end cap, piston seals are defective, or the rock shaft seal has been installed improperly. While there is a seal between the transmission and the rear end, the seal would have to be nearly gone to cause a problem. Even so, that seal would NOT cause the problem you are describing.
triplerange
08-07-2007 05:13:06
 Re: Where are you putting the hydraulic oil? in reply to Roger (Mi), 08-06-2007 19:06:39
It can if he is overfilling it in the wrong place....I think he has a shot transmission/hydr. resevour seal.
