VAC steering
Dickey
08-06-2007 17:38:26
my VAC has a problem where it steers a little left and alot right. i tried to take the front arm off but the huge nut is froze. any sugestions
watsonsgotit
08-06-2007 18:25:18
 Re: VAC steering in reply to Dickey, 08-06-2007 17:38:26
Are you certain it is in the front end? You might want to check the worm gear under the gas tank. If you have the drag link loose, you should be able to tell which end is the problem.
Dickey
08-06-2007 18:41:05
 Re: VAC steering in reply to watsonsgotit, 08-06-2007 18:25:18
Ya, it's just the dude i bought it from put the link on the front so that thel ink would be closer to hitting the left side than the right, so at center, it has more room to go right than left.
TimBinWV
08-06-2007 18:11:47
Heat it,then give it a shot of penetrating oil while hot....just be careful of fire!! No torch?Have a wrench that fits? Place it over nut and smack it with a hammer...jolting one is more effective than steady pressure,sometimes...
