sc oil leak
l gehring
08-05-2007 13:45:56
good afternoon . i have a 43 sc . there is a small oil leak comming out where the starter goes into the flywheel housing . is this normal ? the engine oil level is between the 2 petcocks on the oil pan . is there a gasket in that spot? i haven't removed the starter.
thanks, l gehring
Casekernel
08-06-2007 11:20:52
 Re: sc oil leak in reply to l gehring, 08-05-2007 13:45:56
I made my own by taking cork sheet gasket material and cutting out several rings and fusing them together with gasket goop. So far, so good.
Larry Martin
08-05-2007 15:21:53
There is a cork gasket between the starter and the housing. It was available from CIH.
jal-SD
08-06-2007 08:05:50
 Re: sc oil leak in reply to Larry Martin, 08-05-2007 15:21:53
Tell the C-IH parts guy to check #O5039AB Gasket 08J S (the first digit is not zero, but an "O"), I think that is a valid # for the part you need, I got one for my '54 SC about a year ago & the plastic bag it came in is currently being used as a cup holder on my desk. (My $.02 worth. jal-SD)
