Case 1194 rear lift
R Buckel
08-05-2007 11:16:22
My rear lift will not pick up a round bale of hay. (5 ft x 5 ft) I would guess the hay weighs from 1,000 - 1,400 lbs. I use a finish mower and a 5 ft rotary cutter and the tractor has no problem picking these up. Any suggestions. Should I changethe filter and fluid?
R Buckel
08-13-2007 19:10:28
 Re: Case 1194 rear lift in reply to R Buckel, 08-05-2007 11:16:22
Which O ring?
Gwiz
08-07-2007 13:57:19
Seems to me there is an O ring seal in there which can go bad. Real easy to replace. I was having to rev my engine to lift things. Do a search here on this sight for David Brown 3pt, and throw in Elmer's name in your search. Every issue relating to these 3pts has already been discussed.
James
