range drive shaft on 1030
loneranger27
08-04-2007 19:22:46
I just got my basketcase 1030 home and I am trying to make a list of parts and problems and i noticed today that the range shaft at the flywheel end is cracked back about an inch. Is this a shaft i can weld and grind back down or a replacement repair. Thanks for your input.
DKase
08-05-2007 08:21:59
 Re: range drive shaft on 1030 in reply to loneranger27, 08-04-2007 19:22:46
If it is the trans. input shaft that you refer to it cannot be welded. Trans. shafts and gears are hardened and cannot be welded unless you want to spend more than replacement cost.
