630 Question
630 Case
08-04-2007 15:06:51
The hand cluth on my triple range 630 has very little over-center snap to it. How do I go about adjusting it?
bradley martin
08-05-2007 03:10:15
 Re: 630 Question in reply to 630 Case, 08-04-2007 15:06:51
Remove the top cover of the range shift housing (contains the range shift lever....have range shift in neutral before removing). There is a collar with 2 pins on the input shaft. 1 pin will be engaged and 1 pin will not be. Pull engaged pin out and turn collar(probably clockwise)until other pin snaps in notch.Try hand clutch. Repeat if necessary until 45-55 lbs of force is require to snap hand clutch over center. Replace gasket and replace cover.
