case 42g govenor
DougL
08-04-2007 12:44:52
I have a gas case 420G that does not want to idle down. The govenor is working becuse when you move the throttle shaft with your hand to idle the govenor forces it back open. If you unhook the gov spring it will idle down but even with the smallest tension on the arm the engine is off to the races! That being said it does not over speed. Is there a way to adjust this gov?
Thanks
Doung
C. Amick
08-06-2007 15:50:40
 Re: case 42g govenor in reply to DougL, 08-04-2007 12:44:52
A leaking intake manifold gasket will also cause the same problem you described. Spray around it with a flamable substance with the tractor running and see if the engine speed changes.
