felt seal
newtothisgame
08-03-2007 19:41:55
on a 2x16 case trailer plow on steel is the felt seal suposed to be 2 piece or did it just break if a one piecer where can i find a seal yet
C. Amick
08-04-2007 20:00:09
 Re: felt seal in reply to newtothisgame, 08-03-2007 19:41:55
Is there a metal ring around the outside with a number on it?
newtothisgame
08-05-2007 19:15:05
 Re: felt seal in reply to C. Amick, 08-04-2007 20:00:09
where the metal houseing goes around the trip side and the housing comes apart into two pieces theres a seal that keeps the gear lube in that seal
C. Amick
08-06-2007 15:28:11
 Re: felt seal in reply to newtothisgame, 08-05-2007 19:15:05
Are the parts small enough that you could take them to a seal and bearing place like Motion Industries or can you accurately measure the diameters of the housing and shaft? I'm sure they can match one up for you. It will probably be rubber instead of felt.
