970 pump adjustments
Dairy Farmer in
08-03-2007 19:13:02
i wanted to know how to turn DOWN the pump on my 970. i feel it has too much fuel going to it. no problems with the engine or anything but just want it to not to waste as much fuel,
thanks
DF in WI
massey333
08-05-2007 10:02:23
 Re: 970 pump adjustments in reply to Dairy Farmer in WI, 08-03-2007 19:13:02
Why do you think it is wasting fuel,Smoking(normal),using more fuel than a 40HP tractor doing light loads??You are feeding a 400CID engine and 10,000+LBS.tractor.What is your useage doing what load and maybe we could get a better idea if it is wasting fuel or is normal.
D-C-741
08-04-2007 16:47:56
Just why does it need the fuel turned Down? Have you ever had the INJECTORS tested? or better yet Replaced them ?LOW Opening Presure will Cause it to over fuel. I Would check this First Before PLAYING With the Fuel Settings.
Gene Dotson
08-03-2007 19:36:43
DF; On the rear of your pump is a cover with 4 10mm head bolts. Remove this cover and you will see a screw that is locked with a 10mm head nut. Loosen this locking nut and back the screw out counter clockwise to lessen the fuel. One turn will make a noticable change. Be sure to retighten the locking nut.
As always when working with diesel fuel systems, clean the area throughly to prevene dirt from entering the fuel system... Gene
