Joe(wa) Front Hub
wayne2
08-02-2007 18:06:07
What an active forum!!!! It's the utility w/spindles-NO kingpins-wish I had em when I mounted loader-4" root kicked me in the pants-got drug out by all things a K___TA-I was sick. Wayne
Joe (Wa)
08-02-2007 20:33:33
 Re: Joe(wa) Front Hub in reply to wayne2, 08-02-2007 18:06:07
Dang Wayne, getting info from you is like pulling teeth. If you answer all the questions I posed in the post below I can figure out what hub you have.
All round nose 300 tractors have spindles, either "L" shaped or "U" shaped, they are still spindles.
Utilty 300 tractors have a fixed "I" beam wide front end axle with "U" shaped spindles and king pins.
OR
An adjustable "I" beam front axle with "L" shaped spindles, obviously no king pins. The key words here are ["I" beam axle]. The front end may have been changed out, so answer this question with a simple yes or no and we will go from there:
DO YOU HAVE AN ADJUSTABLE WIDE FRONT END "I" BEAM AXLE?
Joe
wayne2
08-03-2007 06:11:28
 Re: Joe(wa) Front Hub in reply to Joe (Wa), 08-02-2007 20:33:33
Yes, I'm sorry let's blame-Viet Nam- Adj front end!!! Wayne
Joe (Wa)
08-03-2007 18:48:16
 Re: Joe(wa) Front Hub in reply to wayne2, 08-03-2007 06:11:28
The 300 parts manual does not list a dedicated hub for the utility adjustable axle.
I believe these are the correct p/n's for your hub but not 100% sure.
Grease seal:
Case p/n G13053
Chicago Rawhide p/n 19211
Inner bearing cup: Case p/n G57451
Timken p/n LM48510
Inner bearing cone:
Case p/n G57452
Timken p/n LM48548
Outer bearing cup: Case p/n B12410
Timken p/n LM11910
Outer bearing cone:
Case p/n B12411
Timken p/n LM11949
Joe
wayne2
08-05-2007 13:12:17
 Re: Joe(wa) Front Hub in reply to Joe (Wa), 08-03-2007 18:48:16
Joe, I BOW to your Knowledge!!!!!
