SC CASE valve cover gasket...howto replace?
Greenfrog
08-01-2007 19:36:46
I finally located a gasket...cork...I have cleaned the surfaces. I assume I have to used some gasket cement(Permatex) on both surfaces? ...Or is there something new out there? What is the correct procedure?
dboll
08-03-2007 04:59:44
 Re: SC CASE valve cover gasket...howto replace? in reply to Greenfrog, 08-01-2007 19:36:46
silicone is the worst thing to use on a cork gasket, cork is intended to self seal, sealants of any kind makes the gasket want to squeeze out
Greenfrog
08-01-2007 21:43:49
Any particular kind of gasket sealer or can I use the blue silicone gasket "form a gasket" cement/sealer? Yes, I guess that would make sense to only seal it on one side. Thanks to you two replies.....
SC Dan
08-02-2007 06:39:12
 Re: SC CASE valve cover gasket...howto replace? in reply to Greenfrog, 08-01-2007 21:43:49
The blue Permatex Form-A-Gasket is fine, that's the same stuff I use.
Dan
SC Dan
08-01-2007 21:24:57
Only use the gasket sealer on one side. Seal it to the valve cover but not the head. Make sure both surfaces are clean.
Dan
Klyde
08-01-2007 20:38:06
I always glue it to the cover (hi-tack) and then grease the side toward the head. Then if you do have to get in there to check clearance or replace a spring you can usually do it without having to have a new gasket.
