is com converter weak
safe-not-sorry
08-01-2007 07:06:07
I've always driven tractors with a TA not a COM -was wondering if my conveter is weak in 730. In gears 1-3 you can stand on the brakes in fluid drive - no change in speed - in gears 4-5 you can just about bring the tractor to a stop - just feels really wierd - I'd assume 4th and 5 th would have more power than they do. When pulling in the field did you use the fluid drive just to get through tough spots - can't imagine you could pull alot with it when its so soft in mid gear range. My clutch pressure is just into the green when running wide open,my brothers 800 is in green at idle -is this a concern. Acording to the book engine about 400 rpm's short of factory. Taking it to the field this fall and I don't want any nasty surprises. Give me all the info you can - I'd rather be safe than sorry. Sure is a sweet running tractor!!
Phil (NJ,Az,Sask)
08-03-2007 06:35:25
 Re: is com converter weak in reply to safe-not-sorry, 08-01-2007 07:06:07
To help understand the COM system the Clutch Packs operate thus.
Main Clutch Pack (multi-disk): Locks COM unit to the Transmission in Torque or Direct drive (on Back end) This Clutch Pack must be engaged for both modes
Direct Drive Pack: When not engaged the Torque Coverter is operated in Fluid Drive. When engaged the locks the Torus to the turbine (front End) resulting in Direct Drive.
If you have good operation in Direct Drive both Clutches are operating
correctly. The Pump must supply sufficent Volume to maintain clutch
pressure @ 120 PSI in both Torque & Direct Drive.
If weak in Torque Mode (fluid) your Converter Pressure Regulator may be
bad "Spring" (the flow through the turbine is @ 35 PSI at all times) , or you have contaminated Fluid.. over heated Etc
Its a simple System
JMHO
INCase
08-02-2007 08:30:28
I agree with Phil, if there is something wrong with pressures. there are relief and regulator valves and seals internally that can go wrong causing the pressure to be low and having things not work as everything is hydraulicly controled. I may be giving too much info here but understanding the basics of the COM can help figure out if its working. There are 2 clutch units in a COM. one is for the direct drive that locks everything together and acts like a regular clutch and a clutch pack that the torque converter drives. These are both hyd. actuated via the clutch pedal and lever. Have you tried the direct drive out? you should notice a distict "jump" in speed when going from fluid to direct (move lever toward you). I believe you should be able to stop the tractor with the brakes in fluid drive. This will allow you to ease back to hook up implements as it is hard to ease/ride the clutch pedal on a COM (should behave like an automatic car at a stop light). If you have the owners manual it will show a fluid versus direct-drive pulling capability for each gear range. The lower the gear the higher the pulling capacity and in the lower gears you may not be able to stop the tractor with the brakes especially if the brakes aren"t the best. Generally the fluid drive is for very light work (driving around the barn yard with no load) and starting off with a load (plow, loaded wagon ect) once up to speed with fluid drive put it into direct drive. When going down hill you will need direct drive. Hope this helps.
safe-not-sorry
08-02-2007 13:36:34
 Re: is com converter weak in reply to INCase, 08-02-2007 08:30:28
When I put it into direct drive it works great - my concern is that it is so soft in fluid drive in the higher working ranges - should probably run disc in direct drive then?
triplerange
08-02-2007 15:05:20
 Re: is com converter weak in reply to safe-not-sorry, 08-02-2007 13:36:34
yes, run disk in direct. Running a long time in oil drive heats up the oil...that's why they come with COM Temp gauges. My 630 doesn't pull so well in road gear in com drive anymore, but shoot the thing's got over 7500 hrs on it. The COM might be getting weaker...but hey, it works in the other three gears in high range. It only takes off well at idle when there is no load. One time I hauled about 600 bu of corn down the road with that little tractor....pulled the crap out of...I downshifted quite a bit to get up a hill. She still does just fine. Take your 730 to the field...but keep in mind she's over 40 years old and use direct drive!
Phil(NJ,Az,Sask)
08-02-2007 06:39:02
I have the COM tore down on my 530CK because of a complete Loss of pressure in Direct Drive. My problem was a broken Ring seal on the PTO stub Shaft, I think this was broken during assembly the last time it was serviced/apart. I found/think that the COM innards (clutches etc)are near bullet proof and not a normal performance issue.
These would be my suggestions RE: performance/pressure issues without splitting unit. All can be serviced via Adaptor plate
A) Filter
B) Fluid Flush & change
c) PUMP Relief Spring. These wear and Break, pump is mounted under adapter plate D) Clutch Pressure Spring (In control Spool Assembly) (sets Pressure @ 120 with clutch released) E) COM/Convertor Pressure Spring (sets pressure @ 35 with clutch pushed in)
These are easy & cheap
JMHO
Lincoln
08-01-2007 20:18:52
My converter pressure is always just into the green. Seems to be the same at idle or revved up. I've always used the fluid side for starting out, then the direct drive once the tractor and implement are moving. When you get into a tough spot, put it back in fluid drive to work itself through. I've never worked mine too hard, but on the baler it is nice to be able to put it into fluid drive to slow down for tough spots without having to idle the motor down.
wayne2
08-01-2007 19:44:54
WISH I HAD ONE!!!!Change Filter-go for it 7$ Reagon did it!!! Wayne
