Case 580 B brake job right side
Paul Roncallo
08-01-2007 06:40:21
I replaced the brakes on the left side without a problem, I am running into a proble on the right side with differential lock, Is the differential lock removable from the brake housing ? I can't believe case would build a tractor that I am joing to have to remove side rail to get enough clearance to remove housing. It seems to be only a 1/4 inch or so short Anyone who knows the trick by all means let me know. I am hoping the shop manual I ordered will be in todays mail but would like to finish the job if it is not.
Daniel Robertson
08-02-2007 05:01:05
 Re: Case 580 B brake job right side in reply to Paul Roncallo, 08-01-2007 06:40:21
You might benefit from this post a month or so back. I haven't done my brake job yet (to busy) but will be following these guidelines when I do. Will also be interested in how successful your job went. This is the post from;
Roger (Mi) 07-07-2007 19:32:29
205.188.117.70
113609
Rust! in reply to Daniel Robertson, 07-07-2007 12:07:59 It�s a Bendix brake system. It consists of a two-part bands (with riveted linings) going around a two-part drum. When the brake pedal is pushed, the band tightens around the drum. As that happens, the two-part drum (with riveted linings on both sides) will expand as the three steel balls roll up ramps inside of the two-part drum. That action forcefully applies the brakes. It�s a good brake system. However, rust can make them stick or render them useless. On most Case models, the floorboards must be removed to service the brakes. Remove the brake adjustment nuts. Remove the bolts/nuts that hold the brake housings onto the transmission case. --[Removing the brake housings on some backhoe models can be challenging because there is backhoe attachment interference. Either remove the studs in the transmission case using jam nuts or loosen the backhoe supports to get the necessary clearance.]--- Once the housings are removed, look for oil seal leaks. If seepage is evident, the seal/s will need to be replaced. The band that goes around the drum will come off with the brake housing. In the brake housing, there is an anchor stud and two small springs holding the band in place. Knock out the small steel plugs (Yes, the plugs can be reused.) to gain access to the springs. Find a steel rod about 8� long that can fit inside of the springs. Grind a small notch in one end of the rod. That notch will prevent the spring from slipping during removal and installation of the springs. The same tool will work for the two-part drum disassembly and assembly too. Clean out the rust! The brake surfaces where the linings make contact must shine. If not, the brakes will stick or will not work well, or they will chatter. Make sure the internal brake linkages are rust free and lubricated before reassembly. Also, remove any internal rust from the two-part drum. Any badly rusted or stretched springs must be replaced. The brake linings and springs can be purchased at any Case-IH dealer at a fair price. If you don�t have a device for removing and installing rivets, have the dealer or an automotive machine shop do it for you. Before putting the brake housing on the transmission housing, put a bead of sealer around the brake housing contact surface to prevent water from seeping into the brake assembly. When everything is reassembled, adjust the brake pedals to one-inch free travel.
DougM
08-02-2007 08:12:28
 Re: Case 580 B brake job right side in reply to Daniel Robertson, 08-02-2007 05:01:05
third party image
Paul yes the diff lock should come off before trying to remove the brake assembly.once you unbolt the diff lock housing you should be able to work it of the end of the shaft, sometimes the sliding collar can be a little miserable to come of the shaft due to wear, corrosion etc. There are two seals on the diff lock shaft, if you see any signs of oil in the brake housing chane those seals, here is a parts drawing for reference
