RE: To Part or Fix, Case 530
Jeff Jensen
07-31-2007 15:44:08
Need expert advice. A customer of our's owns a Case 530 that just had the motor blow. The tractor has a loader on it. Has an Eagle Hitch with Hydraulics. Fair to Poor condition otherwise. The customer is wondering whether to put another engine in it, rebuild the one he has, or just sell the tractor for parts. What do you think the tractor might be worth?? We think he should sell it for parts rather than continue to throw good money after a rough tractor. Open for opinions. Thoughts?? THANK YOU-Jeff
JGarner
07-31-2007 19:17:13
 Re: RE: To Part or Fix, Case 530 in reply to Jeff Jensen, 07-31-2007 15:44:08
If he decides to part out tell him to e-mail me I have it turned on. There are some common parts that will fit my 630 that I would like to have, maybe we can work out a deal.
bradley martin
07-31-2007 17:36:04
Too many unknowns....gas or diesel?..transmission type? ...tires..etc.How much does he use it? ...sentimental value? etc.etc.
Jeff Jensen
08-01-2007 07:57:27
 Re: RE: To Part or Fix, Case 530 in reply to bradley martin, 07-31-2007 17:36:04
It is a gas. Tires are loaded--decent tread. New rim on the left side. He has another tractor, but not with a loader. They don't have alot of money. They paid too much for the tractor when they bought it at auction. It was bought from a very dishonest/not forthcoming person. Reputation proceeds him. It had problems before they bought it, but were too nieve to realize. They have learned alot now. One of life's expensive lesson's as he says. We did what the customer asked us to fix. We told him after doing a pressure check, that the oil pressure was really low, discovered a knock in the engine. We added a muffler, hooked all lighting/gauges back up on dash, and hooked the air cleaner up-yes, it had been running/working without the a/c in place! We fixed the seat, added oil to hydraulics and put an alternator on it. Generator was burnt right up. We told them the tractor probably won't run much longer when we took it home. It quit two days after. They are farmer's trying to make a living. No sentimental value to the tractor at all. JUST USE IT! He is looking for our opinion what to do.
Thought I would get some input from you folk's who know Case the best. Thanks.
Dennis/Ohio
08-04-2007 00:08:32
 Re: RE: To Part or Fix, Case 530 in reply to Jeff Jensen, 08-01-2007 07:57:27
Hello Jeff,
Is the loader self-leveling? Loader model number? Loader tag is near loader step on left side. A rebuildable engine core may cost $1500
If he could do the work himself OK but paying labor, OUCH....
The larger engines are 2 inches longer than the 159 cu. in. thats in it. The length is a problem because the loader frame wraps around the front of tractor. (Unless this loader is aftermarket) I restored my 530 loader & hoe, great old tractor. Also this could be a 530CK with model# 32 loader which is different from 530 with model# 31 loader. Many 530 parts are no longer available.
Best, Dennis..... ...
Jeff Jensen
08-04-2007 06:37:36
 Re: RE: To Part or Fix, Case 530 in reply to Dennis/Ohio, 08-04-2007 00:08:32
Thank you all. Customer will be selling tractor for parts. Anyone interested, give us your phone#'s and we will pass them along. Appreciate it-jeff
07-31-2007 17:26:09
where is it?
Jeff Jensen
08-01-2007 07:58:46
 Re: RE: To Part or Fix, Case 530 in reply to [email protected], 07-31-2007 17:26:09
Located in Bradford, NY
BarryfromIA
07-31-2007 19:22:01
I have a gas 207 from a 660 combine That I would sell.
Jeff Jensen
08-01-2007 07:59:47
 Re: RE: To Part or Fix, Case 530 in reply to BarryfromIA, 07-31-2007 19:22:01
How much?
