CASE 400 LP
t of nd
07-31-2007 12:49:09
Would someone explain to me how to hook up the battery on a 6 volt system and how to jump a 6 volt system?
C. Amick
08-02-2007 16:17:44
 Re: CASE 400 LP in reply to t of nd, 07-31-2007 12:49:09
I think the 400 has a positive battery ground. Which means the battery cable that is grounded to the tractor body goes on the positive terminal. If I were trying to jump start a 6 volt system with a 12 volt system, I would hook the jumper cables up at the starter just long enough to hit the starter to see if it will start.
t of nd
08-05-2007 06:39:49
 Re: CASE 400 LP in reply to C. Amick, 08-02-2007 16:17:44
Thank you C.Amick that is exactly right. I did more research and found that it does have a positive ground. And I did start it with hooking the positive to the starter for a short second.
