break adjustment
Rick Lawson
07-31-2007 10:23:02
I have a 1969 case 430 gas and dont know how to adjust the breaks
JGarner
07-31-2007 11:02:21
 Re: break adjustment in reply to Rick Lawson, 07-31-2007 10:23:02
Locate the differential brake housings on either side of the differential case just in front of the rear axel housings. There will be a hole with a round threaded shaft sticking out of the front of it. If they are still in place the shaft will have a rubber grommet around it to seal this hole from dust and dirt intrusion.
The threaded end of the shaft sticks through a cast piece that is attached to the shaft that the brake pedals are mounted on (both sides). The threaded piece has two nuts on it, a jamb nut (outer) and an adjusting nut (inner).
While holding a back-up on the inner nut with a open end wrench (3/4" I seem to remember on my 630) loosen the outer jamb nut and screw it off a turn or two. With the box end wrench start to tighten the inner nut. I like about a 1/2 inch of free play when pushing on the brake pedal with my hand, but then mine is the expanding disk kind, not shoes. When the proper amount of play is attained, move to the other side and repeat the process until both pedals have equal free play then tighten the jamb (outer) nuts very tight against the adjusting nut.
The caveat is that you still have brake lining left and the assembly is dry and free of oil. The only way to check this is to remove the brake assembly cover (big cast shell)uness there is visable oil dripping from under the brake cover. If this is the case all of the seals have to be replaced and probably the brake shoes relined. This is a much bigger job than I can explain here, e-mail me and I can send you printed JI Case instructions scanned from my Case service manual.
Jim
