Case LA , Brakes
Ron Gustafson
07-30-2007 16:10:04
Want to know if anyone has had luck rebuilding hydralic brakes on an LA Case? some people say that they dont last but there must be new parts out there of better quality? Please let me know. Thank you, Ron Gustafson.
JGarner
07-30-2007 17:31:50
 Re: Case LA , Brakes in reply to Ron Gustafson, 07-30-2007 16:10:04
Those that say the rebuild doesn"t last may not be honing the brake and master cylinders before reassembly. If you don"t hone out the corrosion and make the cylinder walls slick again, they won"t last. Check with NAPA and see if they have rebuilt "wheel" and master cylinders for your LA, Probably don"t but its wirth asking. Honing takes a long time if the cylinders are pretty corroded. New or rebuilt cylinders are realtively inexpensive.
Mark in Iowa
07-30-2007 17:30:15
O.K. I got this off of this site sometime ago... Brakes are Wagner- Lockhead Master Cyl....FE 1050 Kit....FC 5375 Wheel Cyls....FC 1757 Kit....FC 3618 I haven't had a chance to chek this out...hope this helps... Mark
