Hydraulic Probs, 1978 Case 995
Bill
12-30-1999 07:51:42
My loader hydraulics had become increasingly slower, I overhauled cylinders, fixed various small leaks, found no significant improvement. So I changed out hydraulic oil & filters, problem persists, and has increased.ie sometimes now I can't lift arms more than about 5 ft & there,s nothing more, until it will suddenly "cut in" & work OK.On a slight downward slope (front of tractor down), there's often virtually no hydraulics intil I get on level ground again. Case dealers I checked with said to add a couple of extra gals of oil & try it; I have'nt yet but this answer seems strange since it has always worked fine in the past on correct oil level
Since sometimes hydraulics work fine I'm doubtful that the problem is in hyd pump performance
Any ideas?
hugo peek
12-31-1999 07:21:09
 Re: Hydraulic Probs, 1978 Case 995 in reply to Bill, 12-30-1999 07:51:42
find out what your maximum pump presure is
hugo peek
12-30-1999 15:02:06
