Idling a Case Tractor
prairieplow
07-29-2007 12:08:45
I have a 1937 Case L. When I have the transmission in neutral, am I supposed to run the belt pulley? I know on the old John Deeres, you have to engage the hand clutch and let the transmission run, even though the tractor is in neutral.
dctom
07-29-2007 15:22:49
 Re: Idling a Case Tractor in reply to prairieplow, 07-29-2007 12:08:45
NO NEED TO ENGAGE CLUTCH ON A CASE TRACTOR WHEN IDELING,NOTHING IS TURNING SO NOTHING TO LUB,ONLY SHOWES HOW FAR DEERE WAS BEHIND CASE AT THE TIME LOL
57 Case
07-30-2007 20:08:06
 Re: Idling a Case Tractor in reply to dctom, 07-29-2007 15:22:49
While I don't think you need to engage the clutch on the older chain drive tractors in neutral, on the newer chain drives with live PTO i.e. LA, 500, 600 and so on I think you are supposed to engage the traction clutch if doing stationary work. I would also engage the clutch if I was Idling for an extended period of time. Also If a tractor is in neutral with the clutch engaged it won't accidentally move if someone mistakenly bumps the clutch lever.
bradley martin
07-29-2007 14:32:15
The original owners' manuals for all the chain drive Case tractors states that for stationary P.T.O. or belt pulley work, the transmission should be in neutral and the hand clutch engaged. I assume this assured lubrication as well as reducing friction in the wet clutch components.
Jerry H
07-29-2007 15:41:12
 Re: Idling a Case Tractor in reply to bradley martin, 07-29-2007 14:32:15
If you are doing pto or belt work the clutch will be engaged to make things work
Walt Davies
07-29-2007 12:27:28
I can't see any reason to do it I let my LA run at idle all the time with the clutch out.
Walt
Ande
08-01-2007 05:29:14
 Re: Idling a Case Tractor in reply to Walt Davies, 07-29-2007 12:27:28
Walt
What all do you use your "LA" for? Do you use it in the field? What year is yours? I have a 49,will be running this fall.
Ande
BarryfromIA
07-30-2007 19:17:14
A hand clutch CASE is great for yard chores. You pull the clutch back, set the brake, go open the gate or whatever and when you get back on no grinding in to gear or waiting for the gears to stop turning just hit the brake pedal, push the clutch and go.
