Case 770 powershift/shuttle problem.
Tripond
07-29-2007 09:06:46
I have a Case 770 Tractor 267 ci Diesel. I can shift to any gear and start forward (do not touch shuttle) no problemss once I shift the shuttle to 2nd the tractor will come to an abrupt stop once the clutch is depressed again. If I let the clutch out in neutral it will actually stall the tractor. It appears as though tripping the clutch numerous times will allow the tractor to run again with the clutch out. I have been using the tractor for Haying, with-out the shuttle, Its a real Cadillac! but would be much better if I could use the shuttle. Iwas informed it could be the C-3 spool, I have had out 4 times and lightly cleaned it, it may have worked a couple of times but the last time we took it apart and put it back together it didn't do anything. increasing the RPMS and dumping the clutch many times may have allowed it to return to normal, don't really know, but it did come out of it. any other suggestions. the trans oil temp also seems to get pretty high through-out the day 230+ sometimes, as the temp gets higher the clutch acts jerky at high RPMs. Larry
