Case 730 electrical trouble
Michael 730
07-28-2007 19:59:59
I just bought a 1967 Case 730 diesel that has been converted over to an alternator. I am having some trouble, no power at the key. Would like to see if any one has a diagram I can see.
DKase
07-29-2007 07:08:14
 Re: Case 730 electrical trouble in reply to Michael 730, 07-28-2007 19:59:59
You simply need to get a light tester and make sure the wire from the hot starter post is getting power to the switch. Then test each post on the switch to see if the power is getting through the switch.
07-29-2007 05:11:47
I hope it helps.
https://webparts.pvassociates.net/cnh/main.php
Michael730
07-29-2007 05:50:28
 Re: Case 730 electrical trouble in reply to [email protected], 07-29-2007 05:11:47
Did not work, timed out.
