Case 222 Steering
jester
07-27-2007 08:36:01
My Case model 222-76 has turned in to a NASCAR lawn tractor... It turns great left but take most of the yard to make the same right hand turn. Any thoughts.
Klyde
07-27-2007 12:21:28
 Re: Case 222 Steering in reply to jester, 07-27-2007 08:36:01
Hmmm Did you just replace the tierod ends on the draglink? If you did it needs adjustinng for length. Oh maybe bent it. Easy to adjust, arrow on sector gear points to pinion gear on bottom of steering shaft. Wheels should be strait ahead then. If its slipping by then you need to adjust the sector with the shims on it or get a new sector gear.
Jester
07-28-2007 08:41:07
 Re: Case 222 Steering in reply to Klyde, 07-27-2007 12:21:28
I look at the steering gear and it appeared loose when I went to tighten it well... it snapped. Any idea where I may find the bolt that holds on the steering gear and steering related parts.
John Noname
07-29-2007 18:07:29
 Re: Case 222 Steering in reply to Jester, 07-28-2007 08:41:07
If you need parts go to
www.store.casegardentractors.com
He has most parts.
