Case engines
R oger R
07-26-2007 15:58:25
The more I learn about case tractots the more I realize I know very little. I was told that the crank shaft in the 830 LP (284 cid I beleive) is the same as the diesel (301 I think). Is this true?
bradley martin
07-27-2007 02:40:20
 Re: Case engines in reply to R oger R, 07-26-2007 15:58:25
Early versions did not have the counterbalancer on the crank,,so you could run into a problem if the donor is from a early model and you wish to install it in a later model engine.
rcgrey
07-26-2007 16:18:58
Parts book lists part# A22578 as crankshaft for 730 and 830 gas and diesel engines hope this helps JIM
