Case 530 - Stalls when worked, but starts right up
07-24-2007 18:14:08
Case 530, gas, runs fine at low speed with no load. Put a load on it and it will stall. But starts right up after the stall.
Anyone recognize this symptom? Sediment bowl seems to stay full the entire time when running under any load.
LenND
07-24-2007 18:36:59
 Re: Case 530 - Stalls when worked, but starts right up in reply to [email protected], 07-24-2007 18:14:08
It sounds like a fuel problem. Probably needs a carb cleaning and kit.
08-26-2007 17:07:23
 Re: Case 530 - Stalls when worked, but starts right up in reply to LenND, 07-24-2007 18:36:59
I took your advise, just got the carb back from the shop. Cleaned and new kit installed. Put it back on, fired it up, but no change. Still stalls if you ask it to do any work.
Checked fuel lines, lots of fuel flow, and the bowl stays full all the time. Whats next?
07-24-2007 20:04:00
On a scale of 1-10 how difficult is it to do the carb kit on this tractor?
I'm hoping for a 2 or 3...
CENTAUR
07-24-2007 20:44:10
 Re: Case 530 - Stalls when worked, but starts right up in reply to [email protected], 07-24-2007 20:04:00
Does it have an adjustable main jet? IF so,Open your throttle up to a working speed and open up the main jet to attain maxium RPMS.From what you have said this may not do it if it has a fixed main jet.You did not tell us what brand and/or model your CASE 530 has. CENTAUR
07-25-2007 14:09:39
 Re: Case 530 - Stalls when worked, but starts right up in reply to CENTAUR, 07-24-2007 20:44:10
Plate on right side shows the following, although the hood shows 530..
Model 540
8351634
Engine block plate
G159B
2655544.
I wish I knew more about this old tractor, I suspect if I keep hanging around here I will learn alot. Thanks to everyone ...
630crazy
07-26-2007 16:08:39
 Re: Case 530 - Stalls when worked, but starts right up in reply to [email protected], 07-25-2007 14:09:39
BTW, the info you gave, your tractor is a 1968 utility standard front-end.
630crazy
07-26-2007 16:01:33
Their are two carbs for the 530, Zenith and Marvel Schebler. The Marvel is cast iron and the Zenith is Aluminum. Which carb do you have? Also, is the tractor producing any black smoke or missing? You might have a cylinder not getting spark. Pull the plug wires off one at a time and listen for a change. If you pull a wire off and don't here a change that is the cylinder not receiving spark. And no� the carb kit is not that difficult to put in, just watch how things come apart. Have a digital camera handy and snap a few photos to reference back. The carb kit should come with instructions and the exploded view or the carb.
