Repair of pitted shaft seal areas
JGarner
07-23-2007 10:03:49
Long and short is my PTO shaft was extremely pitted and a new seal, Lucas gear oil would not stop the leak and Case has retired the part.
Faced with a repair weld and macine job I approached the metallurgists where I work for some advice on a repair weld. I was told it could be done but the shaft could warp. One guy came up with a product sample that he had recieved that had several epoxiy based products in it. One was supposed to be for shaft repair and was metal powder impregnated.
This product is FastSteel. Its a two part compond in stick form, you just cut off how much you think you will need, kneed it with your fingers per instructions wet your fingers and apply it to a clean prepared shaft. Let it set for a few hours, machine and polish it to the correct diameter and re-install the shaft. So far it works just like the instructions said, machines easily and polishes well. It is hard and has about the same strenght as annealed brass. The product stayed in the pits when I machined it down and built up the section that was a bit worn. So far it looks like a good product for shaft repair.
SDLars
07-24-2007 14:05:54
 Re: Repair of pitted shaft seal areas in reply to JGarner, 07-23-2007 10:03:49
Thanks for letting us know about another method we can use to keep these old guys turning!
Old Magnet
07-23-2007 12:48:11
Don't need any of that stuff. Get yourself a "speedy-sleeve" by CR and others. It's a thin stainless steel sleeve that presses on the shaft and gives you a new seal surface that will practically last forever. I think all my pto shafts are running with them. They aren't exactly cheap but well worth the money.
benny2
07-23-2007 10:23:56
 Welding warp Re: Repair of pitted shaft seal areas in reply to JGarner, 07-23-2007 10:03:49
I have welded maybe 100s of shafts without warp for just your problem and spun bearings. It all in who does the weld, a guy just has to know how to do the weld. If your plastic dont hold, check with your bearing supplier, they have shaft size repair sleeves, they are thin. Sometimes you will have to replace the seal with another number seal. But with the help of a good bearing parts man this will be easy.
