Hydraulic Hose Crimper .....are they worth buying???
Phil H.
07-23-2007 07:26:21
Every time I break a Hydraulic hose I go through the same thing. It costs a LOT to get a hose made up, but crimping is only $6.oo per fitting, which may or maynot be what everyone else is paying, the point is the fittings and hose seems to be the real cost. Is it worth trying to get the fittings seperate, and hose seperate, and crimping your own, or are the reusable fittings the way to go, provided you can get the ones you need.....thanks....any one with ideas???? Phil
Walt Davies
07-23-2007 20:03:48
 Re: Hydraulic Hose Crimper .....are they worth buying??? in reply to Phil H., 07-23-2007 07:26:21
The reusable fitting are very good and come in almost all sizes and configurations.
Walt
We had a hydraulic hose press at work it cost alot to have all that one needs to fix your hoses. I would think it would be way cheaper to go to town and get one made.
Old Magnet
07-23-2007 08:07:11
The hydraulic hose fabrication has got to be one of the biggest rip-offs going. If you own a hydraulic press you are half way in business. All you need are the crimping dies for the size hose you are dealing with (about $100/set) the crimping bowl a couple of die rings and a pusher that you can buy or make. This would be for the coll-o-crimp system (not sure if name correct) that uses generic swedge fittings. I get my hose and fittings from www.discounthydraulichose.com
No more trips to the "almost right length" hydraulic shop.
Phil H
07-23-2007 09:50:38
 Re: Hydraulic Hose Crimper .....are they worth buying??? in reply to Old Magnet, 07-23-2007 08:07:11
Great idea, I don"t have a hydraulic press but need one, so even more reason to get it now. thanks..... ...Phil
