Case 580ck backhoe gas won't start
DSLRandy
07-22-2007 16:07:06
I am looking at purchase a case 580CK gas backhoe, it has been sitting outside for 3 years. We are able to turn the motor over slowly, even when its boosted it cranks over showly a couple of times then stops.Checked connections all are clean, would a weak solenoid or starter be at fault? It does need a new battery, should I get a 1000 cca for it?
Dennis/Ohio
07-23-2007 04:26:42
 Re: Case 580ck backhoe gas won't start in reply to DSLRandy, 07-22-2007 16:07:06
Hello,
I think removing the starter and have it tested would be cheapest or if you run the starter on the bench and it seems strong & quick, its probably OK. It would be nice to turn the engine by hand but unless you pull the hydraulic pump I don"t know how you can do it.
Best Dennis..... ..
