400 gears
Jim McVay
07-22-2007 12:21:15
I'm working on changing the gears in my 400 Row-crop tractor. The donor tractor is a orchard. I found the Row-Crop has a 9 tooth pinion gear and the orchard ha an 11 tooth pinion. How fast will 1st gear be if I use the orchard pinion gear and have 16.9 x 38 rear tires.
Caseman44 or Harold
07-23-2007 03:00:17
 Re: 400 gears in reply to Jim McVay, 07-22-2007 12:21:15
Hi there, I have 3 CASE 400 Racine Tractors for parts, they are all row crop tractors, two are bell housing on back with all the gears in them yet, I will be pulling the diesel engine out of the 3rd tractor in the near future. Just thought you might need some parts, they are available, drop me an email. Thanks, Caseman44
Patrick Tercho
07-22-2007 17:18:57
Looks like all gear speeds will be 22% faster than with the row crop pinion, Jim. 13-38 speed for 1st in a row crop is 1.4mph so you would be at 1.7mph. It would put you between 1st and 2nd gears right now. Be careful of road gear in this setup, it will be at 17mph, your steering and brakes will have to be in good shape to do this without being a hazard to yourself and others.
