Injector pumps 730/830
justin14054
07-20-2007 14:51:00
will an injector pump from a 730Comfort King work in a 830 caseomatic?Thanks
Justin
chess
07-20-2007 16:01:42
 Re: Injector pumps 730/830 in reply to justin14054, 07-20-2007 14:51:00
Will more than likely fit but will need to be set different by diesel shop -otherwise you will have a very low power 830. Good part is you might be able to step up to 10mm plungers an be able to make some smoke.Bad part it will cost some dough.You can go to cnh web site an compare pump numbers as there are a couple of them. Might also try to get pump from a 336cu in 830 case o matic
